Enable Create Curves by File Dialog
  1. From HyperGraph, open the Build Plots panel, .
    If you want to only use the Build Plots panel, no further action is needed.
  2. From the Build Plots panel, click Dialog to display the Create Curves by File dialog.
  3. The following message is displayed:
    From now on, the Build Plots dialog will only be used instead of the Build Plots panel.
  4. Accept the message to open the Create Curves by File dialog.
    Note: Y Source is the default tab.
