Assign Axes to Multiple Curves Simultaneously
  1. From the Scales, Offsets, and Axis Assignments panel, select the curves you want to assign axes to.
  2. Under Axis Assignments, choose either an x-axis or a y-axis (or both) to assign the selected curves to.
  3. Click Apply.
