Offset Curves Along the Horizontal Axis
  1. Select the curves from the list or pick them from the window.
  2. Activate the X Offset check box.
  3. Enter the distance to shift the curves in the X Offset text box.
  4. Click Apply to accept the new scaling values.
    The data is shifted to the right for positive values and to the left for negative values.
