Move Curves Along the Vertical Axis
  1. Select the curves from the list or pick them from the window.
  2. Activate the Y check box.
  3. Enter a new Y coordinate for the origin of the curve in the Y Move to text box.
  4. Click Apply to move the start point for the selected curve(s).
    The selected curves are moved up for positive values and down for negative values.
