Add a Tracking System
Do one of the following:
  • From the Results toolbar, click . Then, from the Tracking panel, click Add under the Tracking Systems list.
  • Select Create > Tracking Systems from the Results menu.
  • Right-click in the Results Browser and select Create > Tracking System from the context menu.
A new tracking system is added.
Tip: Use the Rename (right-click context menu) option to rename the new tracking system if desired.
