Define a Tracking System By Component
Tracking System by component is only valid for MBD cases. FEA models are not currently supported.
  1. From the Results toolbar, click .
  2. From the Tracking panel, select a tracking system from the Tracking Systems list.
  3. From the Track drop-down menu, select Component.
  4. Select a component which will be used to define the tracking system.
    • Click the Component input collector and select By ID.
    • Pick a component directly from the model in the modeling window.
  5. Under Displacements, use the check boxes to select the axes along which the view will be constrained.
    Option Description
    Global X Locks the view to the X position of the selected entity as it moves. The entity appears to remain stationary along the global X direction during animation.
    Global Y Locks the view to the Y position of the selected entity as it moves. The entity appears to remain stationary along the global Y direction during animation.
    Global Z Locks the view to the Z position of the selected entity as it moves. The entity appears to remain stationary along the global Z direction during animation.
  6. Optional: Activate the Lock rotations check box to lock the rotational movement of the selected entity.
    Entities can be tracked with respect to rotation.
  7. Click the Start/Pause Animation button (on the Animation toolbar) to animate the model.
    The model is animated with respect to the component.
    Tip: A new component can be defined and tracked at any time during animation by picking a different component in the modeling window.
