*beginrepeat2d()
Repeats execution of a block of code a specified number of times.
*beginrepeat2d (expression)
HyperMesh Card Previewer Command
expression
Either a relational expression or an attribute.
*beginrepeat($ARRAY_LENGTH)
*repeatwrap(80)
*repeatcounter(1)
*menufield(Array,integer,$ARRAY_ATTRIBUTE,10)
 *beginrepeat2d($ARRAY2D_LENGTH)
 *repeatcounter(2)
  *menufield(Array2d,integer,$ARRAY2D_ATTRIBUTE,10)
 *endrepeat2d()
*endrepeat()
The *beginrepeat2d() command must always occur with a *beginrepeat() /*endrepeat() block.
The *repeatwrap() command can be used to automatically begin new lines. If used, it must be the first command following the *beginrepeat2d(). If a *repeatwrap() command is specified following a *beginrepeat() command, that same value is used for the *beginrepeat2d() block.
The *repeatcounter() command can be used to store the current repeat value in a counter. If no *repeatcounter() command is specified, the repeat value is not stored in any counter.
All *menufield() commands that reference attributes can only reference the following types in a *beginrepeat2d() block: arrayofinteger2d or arrayofreal2d.
The *beginrepeat2d() command must be accompanied by a *endrepeat2d() command.
