Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
The HyperMesh Card Image panel is used to define solver specific data and review card information. The format of the cards and
the menus in the panel are defined in the export template, using HyperMesh Card Preview Commands.
Returns 1 if "Free format export" option is ON or solver deck is exported using the Tcl command *feoutputwithdata with
option HM_FREE_FORMAT_EXPORT_OPTION.
@checkiffreeformat()
Returns 1 if "Free format export" option is ON or solver deck is exported using the Tcl command *feoutputwithdata with option HM_FREE_FORMAT_EXPORT_OPTION.
@getentitycount()
Returns the entity count of an entity array type data name.
@getentitydefaultstatus()
Retrieves the default status of attribute/dataname of an entity. Returns true if the default status is OFF, or false otherwise.
@getentitytype()
Returns the entity type of an entity array type data name.
@keywordrenumber()
Returns 1 if RENUMBER is passed with the queried keyword via *feoutputwithdata.
@loadexistinmergedloadloadsteptable()
Returns 1 if the load exists in the table containing merged loads for a loadstep created by *createmergedloadloadsteptable().
