@getattributearrayvaluebyinternalid1()
Returns the internal ID of a 1D array attribute attached to an entity.
@getattributearrayvaluebyinternalid1 (entity_type, id, attribute, index)
HyperMesh Template Function
- entity_type
 - The type of entity to query.
 - id
 - The internal ID of the entity to query.
 - attribute
 - The name of the solver attribute array, starting with $.
 - index
 - The index into the array to query, starting with 1.
*variableset(variable2,[@getattributearrayvaluebyinternalid1(loadcols,variable20,$DSLoad_Groups_Name,counter5)])
    Version History
2017.1
