@autocreateproperty()
Returns the status of the "auto create property" export option.
@autocreateproperty ()
HyperMesh Template Function
Returns 1 if the "auto create property" export option is enabled via *feoutputwithdata, 0 otherwise.
*if([@autocreateproperty() ==0]) //do not export unresolved IDs
*string("#Data1")
*end()
*endif()
*if([@autocreateproperty() ==1]) //export unresolved IDs
*string("#Data2")
*end()
*endif()
Version History
13.0
