@entityincollector()
Returns the number of entities in a collector.
@entityincollector (entity type, config_num, type_num)
HyperMesh Template Function
entity type
The type of entity to be counted.
config_num
The configuration number of the entities being counted. If set to 0, entities are counted regardless of their configuration.
type_num
The type number of the entities being counted. If set to 0, all the entities are counted regardless of their type.
