@gettablecolumnentitytype()
Returns the entity type ID of a column in a table.
@gettablecolumnentitytype (table_id, column_index)
HyperMesh Template Function
This function returns the entity type ID of a column in a table. This can be used both inside and outside of a *tables() block. The entity type ID can be converted to the entity type name using @getdatabaseentitytypename.
- table_id
 - The ID of the table.
 - column_index
 - The index of the column in the table, starting from 0.
*tables()
    *format()
        *counterset(counter1,0)
        *variableset(variable1,columns)
        *loopif([counter1 < variable1])
            *counterset(counter2,0)
            *variableset(variable2,[@gettablecolumnsize(id,counter1)])
            *loopif([counter2 < variable3])
                *variableset(variable3,[@getcolumntype(counter1)])
                *variableset(variable4,[@gettablecolumnentitytype(id,counter1)])
                *if([variable3 == 2 && variable4 > 0])
                    *field(integer,variable4,0)
                    *field(integer,[@getcellvalue(counter2,counter1)],0)
                    *end()
                *endif()
                *counterinc(counter2)
            *endloop()
            *counterinc(counter1)
        *endloop()
*output()
    Version History
11.0
