@getentitydefaultstatus()
Retrieves the default status of attribute/dataname of an entity. Returns true if the default status is OFF, or false otherwise.
@getentitydefaultstatus (entity type, entity id, data_name)
HyperMesh Template Function
- entity type
 - The type of entity, such as sets, elems, or nodes, to which entity id refers.
 - entity id
 - The ID of the entity you want to reference.
 - data_name
 - The data name of the entity. For example, ID, name, node1.globalx.
Examples
To get the default status of attribute BCTPARM_REFINE_VAL from property 1:
@getentitydefaultstatus(props,1,BCTPARM_REFINE_VAL)
    Version History
2019
2021.1
