@attributereferencecount()
Returns the number of times an entity is referenced by an attribute.
@attributereferencecount (entity type, id)
HyperMesh Template Function
- entity type
 - The type of entity referenced.
 - id
 - The entity ID.
If you want to output only curves that are referenced, such as by a material or load, use an *if statement as follows:
*curves()
  *format()
   *if([@attributereferencecount(curves,id) > 0)])
      *string("Load Curve #")
      *field(integer,id,0)
      *end()
    *endif()
*output()
      The block above writes out only referenced curves, and those generated via post-processing operations are omitted (if they are not pointed to by an attribute).
