@getattributearrayvalue()
Retrieves the value of a 1D array attribute attached to a specific entity.
@getattributearrayvalue (entity type, entity id, attribute, index)
HyperMesh Template Function
- entity type
 - The type of entity, such as sets, elements, or nodes, to which entity id refers.
 - entity id
 - The ID of the entity from which you want to get information.
 - attribute
 - The name of the attribute (must start with '$').
 - index
 - The index into the array (starting at 1).
