@checkfile()
Checks for a file.
@checkfile (file name)
HyperMesh Template Function
file name
File name to be checked.
*text()
  *if([@checkfile(\tmp\file)=1])
     *string("file exists")
  *else()
     *string("file does not exist")
  *endif()
*output()
Return 1 if the file exists. On a PC, use backslashes for the path (\tmp\file). On Unix, use forward slashes for the path (/tmp/file).
