@getcollectorcardimage()
Retrieves the card image of a collector (such as PSHELL, Part, and so on).
@getcollectorcardimage (collector type, collector id)
HyperMesh Template Function
- collector type
 - The type of collector, such as properties or components.
 - collector ID
 - The ID of the collector.
The following template code outputs the name and card image of every component in the model:
*components("","")
*format()
*string("component: ")
*field(quotedstring,name,0)
*string("card image: ")
*field(quotedstring,[@getcollectorcardimage(comps,id)],0)
*end()
*output()
