@loadexistinmergedloadloadsteptable()
Returns 1 if the load exists in the table containing merged loads for a loadstep created by *createmergedloadloadsteptable().
@loadexistinmergedloadloadsteptable (id)
HyperMesh Template Function
This function returns 1 if the load exists in the table containing merged loads for a loadstep created by *createmergedloadloadsteptable().
- id
 - The ID of the load to query.
*if([@loadexistinmergedloadsteptable(id)])
*string("This is a summed load")
*else()
*string("This is not a summed load")
*endif()
    Version History
11.0.101
