@getcontrolcardattribute()
Returns the value of an attribute on a Control Card.
@getcontrolcardattribute (control card, attribute)
HyperMesh Template Function
- control card
 - The name of the Control Card.
 - attribute
 - The attribute name.
If a Control Card and/or attribute is not present, zero is returned for the menu portion, and an error occurs for the format portion. Use @controlcardattributedefined() to verify the existence of a Control Card or attribute.
