@exists()
Indicates if a pointer is pointing to an entity or if it is set to NULL.
@exists (pointer)
HyperMesh Template Function
- pointer
 - A pointer to an entity. If the pointer is pointing to an entity, the function returns 1. If not, the function returns 0.
