@count()
Counts the entities in the database.
@count (entity type, config, type)
HyperMesh Template Function
entity type
The type of entity to be counted. This parameter may be set to any of the entities in the database.
config
The configuration number of the entities to be counted. This parameter is used only if entity type is set to elements or loads. If set to zero, the entities are counted regardless of their configuration.
type
The type number of the entities to be counted. This parameter is used only if entity type is set to elements. If set to zero, all of the entities are counted regardless of their type.
If the displayed option is selected (active) on the Export Data panel, the value returned by @count() includes only those entities that are currently displayed.
