@ypointelementoffsetvectorlocal()
Transforms a global vector into an elemental system and returns the y value of the transformation.
@ypointelementoffsetvectorlocal (element_id,x,y,z)
HyperMesh Template Function
- element_id
 - The ID of the element to use for the transformation.
 - x y z
 - The components of the vector to be transformed in the elemental system.
*field(real,[@xpointelementoffsetvectorlocal(id,offsetax,offsetay,offsetaz)],8)
*field(real,[@ypointelementoffsetvectorlocal(id,offsetax,offsetay,offsetaz)],8)
*field(real,[@zpointelementoffsetvectorlocal(id,offsetax,offsetay,offsetaz)],8)
None.
Version History
13.0
