*menuoptionenum()
Specifies that the value of an attribute is defined by a previously defined *enumeration() command.
*menuoptionenum (attribute, enumeration)
HyperMesh Card Previewer Command
- attribute
 - The name of the integer attribute that holds the value.
 - enumeration
 - The name of a previously defined enumeration. The value stored in attribute is converted to an integer based on the selection's place in the enumeration and has a value from one to N (where N is the number of items in the enumeration).
*enumeration(Numbers,One,Two,Three)
*menuoptionenum($Numbers_Attribute,Numbers)
*menucase(1)
*menustring("One (1)")
*menucase(2)
*menustring("Two (2)")
*menucase(3)
*menustring("Three (3)")
*menuoptionend()
      For each value specified in the *enumeration() statement that enumeration references, you must have a *menucase() statement. All of the commands between the *menucase()statement that are equal to the value stored in attribute and the next *menucase() or *menuoptionend()statement are executed.
The attribute's value is displayed in the options (bottom) portion of the menu as a selector. You can choose from the values in the enumeration.
