*menuinitialvalue()
Sets the initial value of an attribute if the attribute does not currently exist on the entity.
*menuinitialvalue (value)
HyperMesh Card Previewer Command
- value
 - Can be an expression for real or integer attributes, or a string for string attributes.
May be combined with *menulegalvalue(), *menuenum() or *menurestrictedvalue() modifiers. If the attribute already exists on the entity, its value is not changed by the command. This command must follow a *menufield() command that references an integer, real, or string attribute.
