HMMOD_elementcentroidalresultstohmreslib()
Transfers the current values associated with the element centroidal results to hmreslib.
void HMMOD_elementcentroidalresultstohmreslib(int layer, int index);
HyperMesh hmmodlib Function
layer
The layer of the element whose centroidal values are to be transferred.
index
The index into the array of centroidal results associated with each element.
None.
