HMMOD_noderesultstohmreslib()
Transfers the current values associated with the node results to hmreslib.
void HMMOD_noderesultstohmreslib(int layer, int index);
HyperMesh hmmodlib Function
layer
The layer of the element whose nodal results are to be transferred.
index
The index into the array of node results associated with each node.
None.
