Create, delete, and edit measures.
annotation
measure
create
<type><label>
annotation
measure
curve
<name>=<value>
annotation
measure
delete
all
annotation
measure
delete
<label>
annotation
measure
global
<name>=<value>
annotation
measure
<label>
argument
<name>=<value>
annotation
measure
rename
<label>
<new label>
Arguments
- create
- Create a measure.
- <type>
- The type of measure to create. Options include:
- staticminmax
- dynamicminmax
- minimumdistance
- distancebetween
- incrementaldistance
- relativedisplacement
- trueangle
- relativeangle
- anglebetween
- position
- nodalcontour
- elementalcontour
- nodepath
- circularradius
- yawpitchroll
- <label>
- The measure name.
- curve
- Create curves based on measures.
- measure=<label/id measure list>
- Select a specific measure(s) or a range of measures to
create the curves from. For example:
- measure=1,4-5,8 (recorded when no measure groups
exist)
- measure="Measure 1","Measure 2","Measure 3"
(user-defined in the HWC console when no measure
groups exist)
- measure="i:3 m:3-5,7" or "i:3 m:1,3-5,7" (recorded
when measure groups exist)
- plot=<preview/new/target>
- Preview a curve, or select a destination for the curve.
- preview
- Displays the curve on the right-side preview
plot window.
- Selecting multiple measures to preview is
possible, if the measure items selected have the
same axes types. Otherwise, the following message
is displayed within the dialog
- new
- Create a new window for the plot.
- target
- Select a specific page/window combination. For
example, plot="p:2 w:1".
- livelink=<true/false>
- True establishes a link between the
selections on the Measure panel and the curve in the
HyperGraph window. (Live) is
added to the name of the measure item and the curve name to
indicate that a live link is established. When a live
measure item is deleted, a message is displayed prompting
you to keep or delete the curve.
- livelink is not available for
plot=preview.
- singlecurve=<true/false>
- True enables the X-axis option. This
option is only available for single entity measures such as
Position, Relative Displacement, Nodal/Elemental Contour,
and Yaw Pitch Roll, and is useful for plotting path measures
of discrete selections.
- xaxis=<xaxis_datatype>
- Select the X-axis for the curve (if available).
- This option is available only if the
singlecurve=true.
- yaxis=<yaxis_datatype>
- Select the Y-axis for the curve.
- The available options depend on the group measure type.
- delete
- Delete a measure.
- <label>
- Select or enter the name of the measure to delete.
- global
- Define measure display options.
- transparency=<true/false>
- Removes the color from the measure group box and makes it
transparent against the window.
- autohide=<true/false>
- Hides the measure group box when the selected entities are
not visible on the screen.
- prefix=<true/false>
- Shows the prefixes for the measure readouts (for example,
"Value =").
- format=<scientific/fixed>
- Select the Fixed or
Scientific format for the measure
labels.
- precision=<1-10>
- Sets the numeric precision from 0 to 10 decimal points.
- angle=<degrees/radians>
- Select either Degrees or
Radians as the unit format to
display the angle.
- <label> add
- Apply parameters to the measure. <label> is the
measure name. Options include:
- type - <type>
- tracking - <true/false>
- resolved system - <system>
- add - <entitytype> <entity id>
- edit <item id> <entitytype> <entitytype>
- remove - <item id> <item id range>
- display – Display the following attributes:
- font=<font>
- fontsize=<fontsize>
- id=<true/false>
- name=<true/false>
- visibility=<true/false>
- system=<true/false>
- min=<true/false>
- max=<true/false>
- value=<true/false>
- distance=<true/false>
- nodepath=<true/false>
- magnitude=<true/false>
- x=<true/false>
- y=<true/false>
- z=<true/false>
- trueangle=<true/false>
- xprojection=<true/false>
- yprojection=<true/false>
- zprojection=<true/false>
- radius=<true/false>
- ctrx=<true/false>
- ctry=<true/false>
- ctrz=<true/false>
- rename
- Rename a measure.
- <label>
- Select the name of the measure you want to rename.
- <new label>
- Enter the new name for the measure.
Examples
Create a measure of type
staticminmax:
annotation measure create Measure Group 3 staticminmax
Apply transparency to a measure
group:
annotation measure global Measure Group 3 transparency true
Rename "Measure1" to
"Measure2":
annotation measure rename Measure1 Measure2
Create a curve from a
measure:
annotation measure curve measure=4 singlecurve=true xaxis=Distance yaxis=X
annotation measure curve measure=4 livelink=true yaxis=Y
