tracing
Use tracing commands to trace system, component, and node entities during animation.
tracing entity argument argument ?argument? ?argument?
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Trace components during animation.
Define the display options for traced nodes or lines.
Export the trimmed line definition file as a text file.
Trace lines during animation using nodes.
Select a tracing mode option.
Trace nodes during animation.
Trace systems during animation.
View manipulation.
Perform actions on XY plot files.
