tracing node
Trace nodes during animation.
tracing node add <id>
tracing node color <color value>
tracing node remove <node ID>
Arguments
add
Select the nodes to trace.
<node_id> <node_id list>
Define by component ID or list of IDs.
select
Select from the modeling window.
color
Select a node color.
<color>
Display the color picker.
<RGB/label/value>
Enter an RGB value or selecting a color from the list.
remove
Remove the nodes from being traced.
<node id>
Define by node ID.
select
Trace a node during animation:
tracing node add "Node 22101"
Remove a node from being traced:
tracing node remove 22472
