explode makecurrent
Makes the currently selected explosion active and displays it in the modeling window.
explode makecurrent <label>
Arguments
- <label>
- The name of the explosion to make current.
explode makecurrent "Explosion 3"View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
explode makecurrent "Explosion 3"© 2022 Altair Engineering, Inc. All Rights Reserved.
