kpi hotspot delete
Delete a hotspot query.
kpi hotspot delete <label>
Arguments
- <label>
- The name of the hotspot query to delete.
kpi hotspot delete "Hotspot Query 2"View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Clears the current hotspot.
Import or export hotspot search criteria.
Create a hotspot query.
Review and edit the display options for a hotspot query.
Define hotspot finder search criteria and label options.
Rename an existing hotspot query.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
kpi hotspot delete "Hotspot Query 2"© 2022 Altair Engineering, Inc. All Rights Reserved.
