open hwcfile
Execute an HWC script file.
open hwcfile <hwc log file>
Arguments
- <hwc log file>
- Use the file browser to load the HWC log file.
open hwcfile C:\working_directory\session_logfile.logView new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Open model and result files.
Open a session file and set parameters.
Import a session using default parameters.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Open files.
open hwcfile C:\working_directory\session_logfile.log© 2022 Altair Engineering, Inc. All Rights Reserved.
