result tensor
ClassicCreate and manage tensor plots.
result tensor argument ?argument? ?argument? <name1>=<value1>
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
ClassicCreate and manage iso plots.
ClassicCreate and manage the contour plot.
Set the current simulation.
Makes a subcase current.
Clears the tensor plot and returns the model to its original state.
Changes the tensor color by direction.
Changes the value display.
Clears the tensor plot from the graphics window.
Edits the tensor plot legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
ClassicLoads and plots the tensor data type.
The multiplier for scaling the result values.
Displays the current tensor plot in the modeling window.
ClassicCreate and manage vector plots.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
