result vector
Upfront Data LoaderCreate and manage vector plots.
result vector argument ?argument? ?argument? <name1>=<value1>
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Upfront Data LoaderLoad and unload animations.
Upfront Data LoaderCancels all currently loading results.
Upfront Data LoaderCreate and manage iso plots.
Upfront Data LoaderCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
Upfront Data LoaderCreate and manage tensor plots.
Clears the vector plot.
Changes the vector color for the components or resultant by direction or value.
Upfront Data LoaderCreates a vector data type.
Upfront Data LoaderDeletes vectors from the model.
Changes the value display.
Upfront Data LoaderEdits the vector data type.
Clears the vector plot from the modeling window.
Edits the vector plot legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots the vector data type.
The multiplier for scaling all the result values.
Upfront Data LoaderPlots the vector data type results.
Upfront Data LoaderRenames the vector definition.
Vector plot section options.
Displays the current vector plot in the modeling window.
Upfront Data LoaderUnloads a vector data type.
Upfront Data LoaderUpdates a vector data type.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
ON THIS PAGE
ON THIS PAGE
