tracking create
Creates a new tracking system.
tracking create <name>
Argument
- <name>
- The tracking system name.
tracking create "Tracking System 1"View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Deletes a tracking system.
Applies options to the current tracking system.
Activates a tracking system.
Renames the tracking system.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
tracking create "Tracking System 1"© 2022 Altair Engineering, Inc. All Rights Reserved.
