hgtrans config GetChannelSelected
Gets whether a data channel is marked for translation.
hgtrans config GetChannelSelected subcase, datatype, request, component
HyperGraphTrans Tcl Get
This command gets whether a data channel is currently marked for translation (true or false).
subcase
The name of the subcase from which to read.
datatype
The name of the datatype from which to read.
request
The name of the request from which to read.
component
The name of the component from which to read.
Sets hgtrans to read a single channel from a file called “columns.dat” and then checks that setting.
hgtrans control SetFile "columns.dat"
hgtrans control SetOutputFile "columns.abf"
hgtrans config SetChannelSelected "" "Unknown" "Res. ang acc (rad/s**2)" "column 2"
hgtrans config GetChannelSelected "" "Unknown" "Res. ang acc (rad/s**2)" "column 2"
Error
None.
Keywords
get channel selection
