hgtrans control SetTimeScaleFactor
Sets the scale factor for all time channels.
hgtrans control SetTimeScaleFactor value
HyperGraphTrans Tcl Modify
This command sets the scale factor that is applied to time channels. By default, the factor is one.
value
Value must be a positive, non-zero number.
Cause hgtrans to read everything from a MADYMO file called “ANGACC” and save it to “ANGACC.abf”, scaling the time channel by one thousand.
hgtrans control SetFile "ANGACC"
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control SetTimeScaleFactor 1000
hgtrans control StartTranslation
None.
Keywords
set time scale factor
