hgtrans result GetSubcaseList
Gets the list of subcases in the current source file.
HyperGraphTrans Tcl Set
This command gets the list of subcases available in the current source file.
Set hgtrans to read from a file called “ANGACC” and then query the subcase list.
hgtrans control SetFile "columns.dat"
Returns an empty string if no source file is available or it cannot be recognized.
Keywords
get subcase list
