::hwp::GetExplosion
Gets an explosion handle of an animation client.
::hwp::GetExplosion
HyperWorks Tcl Query
This procedure implements minus options.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a note handle of the active window.
If no model ID is given, then it returns the active model of the requested client.
Mandatory Arguments
None.
Optional Arguments
-id "explosionID"
The explosion ID of the requested explosion.
Default is the active explosion.
-modelHandle "model handle"
The model handle, where the explosion is requested.
-id "modelID" is the model ID of the requested model (of the explosion).
Default is the active model.
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
Returns
Returns an explosion handle of an animation client (based on a model).
set explosionHandle [::hwp::GetExplosion -id 2 -page 4 -window 2]
