::hwp::GetVerticalDatum
Gets a verticle datum handle of a plot client.
HyperWorks Tcl Query
This procedure implements minus options.
This procedure returns a vertical datum handle of HyperGraph.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a note handle of the active window.
Mandatory Arguments
None.
Optional Arguments
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested datum line.
-id "datumID"
The datum ID of the requested datum line.
Returns
Returns a header handle of a plot client.
set verticalDatumHandle [::hwp::GetVerticalDatum -id 2]
