plt3DIAxis SetIncrement
Sets the spacing between tics for the axis.
plt3DIAxis_handle SetIncrement increment
HyperWorks Tcl Modify
This method is only valid for axes using the increment method.
increment
The desired spacing between tics for the axis.
Returns success or an error code.
