plt3DICursor FindLocalMin
Moves the cursor to the local minimum of one component of the plot along an axis.
plt3DICursor_handle FindLocalMin component axis direction
HyperWorks Tcl Query
component
The component (X, Y, or Z).
axis
The axis to scan (X, Y, or Z).
direction
Either "forward" or "backward".
To find the next local minimum Z value along X:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle mySurfaceName 1
mySurfaceName GetCursorHandle myCursorName 1
myCursorName FindLocalMin "z" "x" foreward
If no further minima exist, the cursor is not moved.
