plt3DICurveGroup SetMetaData
Associates a named meta-data value with the curve.
plt3DICurveGroup_handle SetMetaData name value
HyperWorks Tcl Modify
Metadata can be any string or string representation of a number.
name
The name of the value.
value
The value itself.
To set and get a meta-data value from an existing curve:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName SetMetaData species monkey
myGroupName GetMetaData species
None.
