plt3DINote SetI
Sets the note’s I position.
plt3DINote_handle SetI j
HyperWorks Tcl Query
This command sets the note’s I position. The I position is the column position of the note attachment point.
Note: This command will not work unless the note is attached to something.
j
The input for the j variable is the column value (i position along the i axis) of the attachment point of the note.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNoteHandle n1 1;
n1 SetI 92;
Success (0) or an error is returned.
Keywords
  • HyperWorks
  • Tcl
  • Note
  • Plot 3D
  • Query
