plt3DIPlot SetShiftPicking
Sets whether the client receives shift-picking information.
plt3DIPlot_handle SetShiftPicking enabled
HyperWorks Tcl Query
If the client enables shift picking, it will receive a notification through the ::plot3d::PickObjectByVarname routine in Tcl.
enabled
Enabled, true or false.
To check for shift picking in an existing plot:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetShiftPicking
Success (0) or an error code.
