txtIReportManager SetDefaultBackgroundColor
Sets the default background color.
txtIReportManager_handle SetDefaultBackgroundColor color
HyperWorks Tcl Modify
This command sets the default text background color in TextView. You must open a new TextViewsession to notice the changes in the default settings.
color
The number representing the index (position) of the color (from the color palette) that you want to set as the default background color.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr TextEditor;
mgr SetDefaultBackgroundColor 16;
Keywords
HyperWorks
Tcl
Text Edit
Modify
