txtITextEditor SaveTextFile
Saves the content of the text editor to a file.
txtITextEditor_handle SaveTextFile filename, type
HyperWorks Tcl Modify
This command saves the content of the text editor to a file.
filename
The name of the file.
type
Type of file that you want
file
template
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle txt;
txt SaveTextFile MyFile.tpl template;
Keywords
HyperWorks
Tcl
TextView
Modify
Create
