Menu Bar
The menu bar contains pull-down menus that provide access to standard functions such as New, Open, Save and Undo/Redo. This is also where you can access system preferences, and the help.
The menu bar is located directly under the title bar.
The menu options available vary depending on the product and user profile loaded.
