Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer)
these files in the main input deck.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Import Files Import various file types into the selected client.
Warning Messages When Loading Files
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load Files
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save Files
Save all of the data in your current session.
Export Files Export various file types from the selected client to another format.
Include Files
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
