FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Introduction to Sketching
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
Variables
Create and assign variables to parameters when modeling.
New Sketch
Start a new sketch and select a sketch plane.
Project
Project selected geometry onto the sketch plane as construction geometry.
Intersect
Extract curves resulting from the intersection of the sketch plane with selected parts.
Point/Lines
Sketch and edit a point, line, polyline, or line-arc.
